How to perform a dig command using iControl?
Im trying to figure out any information on using dig commands or its closest equivalent using iControl?
Do you want to execute dig on the target BIG-IP remotely to (perhaps) test the DNS resolver on the box? If so, executing ping via POST /mgmt/tm/util/ping would do. Pinging to a remote device with its domain name would resolve its IP address. For example, ping’ing to www.google.com from my test BiG-IP;
curl -sku admin:admin https://<BIGIP>/mgmt/tm/util/ping \
  -X POST -H "Content-Type: application/json" \
 -d '{"command":"run", "utilCmdArgs": "-c 3 www.google.com"} ' | \
 jq -r .commandResult
PING www.google.com (172.217.14.228) 56(84) bytes of data.
64 bytes from 172.217.14.228 (172.217.14.228): icmp_seq=1 ttl=128 time=198 ms
64 bytes from 172.217.14.228 (172.217.14.228): icmp_seq=2 ttl=128 time=198 ms
64 bytes from 172.217.14.228 (172.217.14.228): icmp_seq=3 ttl=128 time=199 ms
--- www.google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 198.649/198.974/199.350/0.288 ms
P.S. Do not forget the “-c 3” ping command option. Otherwise, the ping runs forever, which results in REST call timeout. See man ping.
Ah, we do have /mgmt/tm/util/dig endpoint.
curl -sku admin:admin https://$HOST/mgmt/tm/util/dig \
  -X POST -H "Content-type: application/json" \
  -d '{"command":"run", "utilCmdArgs":"www.google.com"}'  | \
; <<>> DiG 9.11.8 <<>> www.google.com
;; global options: +cmd
;; Got answer:
;; ANSWER SECTION:
www.google.com.         93      IN      A       216.58.193.68
