Hi All,
I am looking for historical connections utilization data of applications hosted on F5 LTM. Is there any way to check the same?
Hi All,
Hi @Vshah ,
If yiu have AVR module licensed on your box , you can collect everything related to specific virtual servers/ Applications.
you will be having great visability on application urls , transactions , ips , Geolocations , which heavy urls that have and …etc.
Let me know if you have this module , I can guide you to use it properly.
If you need to know about it and how to provision it in your box , have a look at the below Article :
Thanks for your response. Yes I am using AVR module.
Kindly guide me how can I get the data from that.
Hi @Vshah ,
you are welcome,
AVR is a very useful module to collect huge amount of metrics and application statistics :
First I will tell you the needed steps and will attach an article will help you in details :
1- create a custom analytic profile , Local traffic >> profiles >> Analystics >> HTTP Analytics >> and
hit create.
2- Select in the profile all needed metrics that you want to collect and select the virtual server that you need to collect these metrics for.
Note : you can add multiple virtual servers as you can , but please monitor your CPU and memory because AVR consumes little bit CPU , if you have a free in CPU and memory it would be great.
3- Hit Finish and wait almost 10 minutes , for changes to take effect and the bigip recieve a sufficient traffic.
4- After that let’s say 1 hour for example :
Go to Statistics TAB >> Analytics >> HTTP >> Overview.
you will see the magic
you can navegate all statistics also play with time slots and you can export a pdf report to review everything offline and extra …
Please Review this article for more details :
I hope this helps you ![]()
