How to activate F5 VE License Key?
I have two F5 VE VM running BIG-IP 11.3.0 Build 39.0 VE Trial 11.3.0-HF1 (based on BIGIP 11.3.0HF6. I decided to buy license now and I bought two license key from cdw in $95.
Now how do i put new registration key in F5? In GUI i can’t see anywhere i can put new key?
In License tab i can se re-activate but it is not allowing to put new Key.
I check this document 404 Page not found | BIG-IP Documentation
But it is very confusing, what i need to do in order to activate key?
After logging into the GUI of the BIG-IP browse to System > License > and select Re-Activate at the bottom of the screen. After clicking Re-Activate click on Edit next to the field that says Base Registration Key. This should allow you to update the license key.
When you click re-activate, click the edit button to the right of the existing reg key.
I am not getting any “EDIT” button in License tab :frowning:
I removed license key from command line and tried to active from GUI and got following error
Licensing Error: Error 51133, F5 registration key is not compatible with the detected platform - This platform, “Z99V”, cannot be activated with this registration key “XXXXXX-XXXXXX”
This is the key I bought BIG-IP Virtual Edition Lab License - license - 10 Mbps - F5-BIG-VE-LAB-V13 - Network Management - CDW.com
Looks like you originally installed the “trial” version. It can not be upgraded as it is neutered. You will need to down the the actual ova from downloads.f5.com. If you don’t have an account you can create one with your newly purchased key.
Do you know where i can download new VE? all i am seeing is Trial version :frowning: F5 has crappy website which is not user friendly :frowning: Please provide me link so i can click and download what i need… also i bought BIG-IP Virtual Edition Lab License ( v. 13.X ) - license key But in Download section i can see latest on is BIG-IP V12.X / VIRTUAL EDITION Does v13.x key will work
v12 VE, Page has moved. You will have to choose which HyperVisor version you want.
v11.6 VE, Page has moved
Okay! downloading for ESX 5.x but does my v13.x Key will work on v12 VE?
Yes. The v13 on the end of you license means it will work up to v13 when it comes out. 404 Page not found | BIG-IP Documentation
I have seen two version in download page BIGIP-12.0.0.0.0.606.ALL-scsi.ova BIGIP-12.0.0.0.0.606.LTM-scsi.ova What is the different between them? what does “all” means?
