form sso not working
Deployment is APM+LTM, logon and authentication happen on APM, after that it pass to pool member which is a vmware accesspoint and further connect to a VMware connection server.
Currently the client-initiated form sso is not working, I’m able to locate the form should be in one URL.
GET /portal/webclient/views/web/home.html?v=3976975 HTTP/1.1
the response contains a form.
But it seems the form has no action? where it put those username/password to?
If i just replace username/password with %{session.sso.token.last.username} and %{session.sso.token.last.password}, it doesn’t work, it seems need some more info.
If i initiate a session with fiddle, I can see my credential is passed through a POST to /broker/xml
POST /broker/xml HTTP/1.1:
Accept: */*
Content-Type: application/x-www-form-urlencoded; charset=UTF-8
X-Requested-With: XMLHttpRequest
Referer: https://ap.test.pss.com/portal/webclient/index.html
Accept-Language: en-US
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/5.0 (Windows NT 6.1; Trident/7.0; rv:11.0) like Gecko
Host: ap.test.pss.com
Content-Length: 407
DNT: 1
Connection: Keep-Alive
Cache-Control: no-cache
Cookie: com.vmware.vdi.broker.location.id=479a25d4-ad86-449e-8b62-4cef5de9d225, maxAge=2147483404s, secure, HTTPOnly; LastMRH_Session=cf60c14d633d8537b0363910eb326d38; MRHSession=cf60c14d633d8537b0363910eb326d38; JSESSIONID=BFB1684B014ED279B16C936E4E8F78EE; clientInfo=eyJhY2NlcHRMYW5ndWFnZSI6ICJlbi1VUyIsICJjbGllbnRWZXJzaW9uIjogIjQuMS4wIiwgImxvZ0xldmVsIjogIjEiLCAiY2xpZW50SVBBZGRyZXNzIjogIjEwLjMzLjIzOC4xNzUsIDEwLjMzLjIzOC4yMDEiLCAiY29udGV4dFBhdGgiOiAiL3BvcnRhbCJ9; ACCESSPOINTSESSIONID=01889370-2994-48b2-9c5b-2985898cb7b4; F5_ST=1z1z1z1468378760z604800; ITO=; UID=; TID=; DID=; STI=; HID=; TCAT4pss.com1468378004801=1; CID=AgAAAP5/KR22Kr3zTqmSinRn3Bg=
windows-passwordusernamejackdomainTESTpasswordCisc01234
Even after that, there is some additional XML data (broker version, user-agent) to same URL.
Any direction on how to get this work?
You can use client initiated to work with most forms, you will need to find out what is called when you click submit so that you can simulate that with javascript.
-Seth
