F5 VE Trial version Failover issue
I have two F5 Trail version and trying to configure HA failover but on status it is showing “Disconnected” Question is does Trial version support HA Failover?
I google it but not get concrete answer from anywhere. Does anyone just tell me whether it is supported or not so i stopped hitting my head against wall.
BIG-IP 11.3.0 Build 39.0 VE Trial 11.3.0-HF1 (based on BIGIP 11.3.0HF6)
Satish,
There’s been a few posts on DC around this subject. The simple answer is HA is not supported with the trial version. I’d get your friendly reseller or F5 themselves to provide you with an eval license which will support this feature. there’s also the lab license too (i think it was $99).
Hope this helps,
N
