F5 SAML SP for a portion of a website
Let’s say I have the following setup:
  • a website called
    test.example.com
  • an access policy called
    test_apol
    with SAML Auth
If I assign the
test_apol
access policy to
test.example.com
VIP, the entire
test.example.com
becomes Service Provider (SP) and is protected by SAML Auth.
Can I, and if yes then how, place only a portion of the website, i.e. a selected list of HTTP Paths/URIs behind SAML Auth, instead of the entire website?
I.e. if
test.example.com/private
then SAML Auth, otherwise no restrictions.
Just from top of my head, I was thinking about placing an iRule Event in front of SAML Auth; and inside iRule do the filtering of which HTTP Paths/URIs I want to send to SAML for authentication, and which ones just straight to the back-end servers without any authentication:
However, I don’t know whether this is the best approach to address my problem, or there is a better more elegant solution.
Any ideas, suggestions, recommendations to address this are much appreciated.
You can use the
ACCESS::enable
and
ACCESS::disable
to disable or enable the access policy for some parts of the website. Check out the article below:
