F5 Rules for AWS WAF - Bot Protection Rules
Bot Protection Rulesを使って、
 特定のURLに30秒間で20回アクセスがあった場合に、それ以降のアクセスを拒否する
というルールを作成すること可能でしょうか?
Using Bot Protection Rules,
  Deny further access if a specific URL is accessed 20 times in 30 seconds
Is it possible to create a rule?
Hi Motoki,
You can achieve the desired behavior outside of F5 managed rules by adding a new rule to the AWS Web ACL.
While AWS may change the configuration process in the future, currently, go to Web ACLs, select the Rules tab, and click “Add my own rules and rule groups”. Then, use Rule Builder to create a Rate-based rule as needed.
Hope that helps!
@motoki - if this reply helped; please consider marking it as solution. Thanks.
