I have rSeries F5 host running on version 1.5.2-21056 and tenants running on firmware version 15.1.5.1 0.0.14. Now I have a requirement to upgrade the tenant to version 16.1.3.5
Can anyone please suggest if it is possible to upgrade only 4 tenants and leave 2s running on version 15.1.5.1 0.0.14. I have total 6 tenant running on this host.
rseries tenants do not support v16 as far as I am aware. You have to go to v17.
Taking in mind that v16 is also EoSS I don’t see any reason not to go to v17 anyway.
It’s absolutely fine to run different versions across tenants. Each tenant operates independently, so they can run separate versions without any issues.”
I wanted to add our Software Support Policy in addition to what Aswin_mk and Injeyan_Kostas have already provided you with. We highly recommend when looking at upgrading your software that you do so within the supported versions.
Thanks for being a part of our DevCentral community!
