Hi All
currently i have an application that looks up for a DNS name in AD DNS server which is loadbalanced between two hosts with Round RObin Method
For Example
Testserver ------- DNS A Record
Resolves to below two servers
Test Server1 --- 10.0.0.10
Test Server2 --- 10.0.0.11
What we would like to do is migrate the similar setup from AD DNS based to F5 - Virtual Server
What i have done so far is as per below
Create A Virtual Server with ANY port (As Service Port)
Then Pool Members - Test Server 1 on port 8000 and Test Server 2 on port 8001.
When the client initiates the requests without port number - NO reponse
When client inititiates the request with port number (8000 or 8001) -- then it will get the response
What we would like to see is this to work with out mentiong any por number
is it possible
if not can we do similar sort of name resolution load balance using F5 instead of AD-DNS based?
