If I have 4 IP addresses behind a F5 load balancing device, and I send a request to the F5, is there a way by means of commandline utilities that I can determine where the F5 would have sent the request Thanks
At a minimum you could log the load balancing decision:
when LB_SELECTED {
log local0. "Client: [IP::client_addr] load balanced to [LB::server addr]"
You can also tcpdump on the internal interface (where the servers sit) and watch where the traffic is going.
