Hello, I am learning about F5 cookie persistence, and I have searched through many of posts.
I curious that when we use cookie passive method, how can F5 know that which client belongs to which servers. Where does F5 store the information, i have try to look at persistence record in GUI as statistics ›› Module Statistics : Local Traffic ›› Persistence Records. But not found anything.
Are you looking for the current connection table on your LTM? You can see this using the tmsh shell. The command “show sys connection”
You will not find anything. F5 doesnt care… since passive mode is where the server and client interact with cookies and the normal timeout/expiration is evaluated by the server when a cookie is presented back on subsequent connections.
- HTTP Cookie PassiveUsing the HTTP Cookie Passive method is unlike the other cookie persistence methods. The BIG-IP system does not insert or search for blank Set-Cookie headers in the response from the server. This method does not try to set up the cookie. With this method, the server provides the cookie, formatted with the correct server information and timeout.
I am looking for a cookie information, that where F5 store information about what cookie belong to which server.
Can we check that where F5 collect the information of cookie?
Think you are missing the point of a passive cookie:
In Passive mode the Big-IP does not search or insert cookies into the HTTP header of responses from the server
Thanks @whisperer i think i got it now.
In passive mode there is nothing created or stored on the LTM. The cookie is generated by the pool member on the initial connection. This cookie is only inspected by the LTM to direct the client back to the same member if it is supplied by the client on further communications.
But when client send traffic to F5, how F5 knows that which server that the traffic need to be sent?
Each server is configured to send the client a cookie that indicates which pool member to use for any further communication during the session. If the server is not configured to issue a cookie in the correct format, passive mode persistence will not work properly.
The cookie uses the format detailed in this article: K6917: Overview of BIG-IP persistence cookie encoding
