I’m using F5 BIG-IP and NGINX Plus Ingress Controller (NPIC) integrated via IngressLink. While attempting to forward the client IP and port by enabling the Proxy Protocol, we encountered the following issue and are seeking assistance.
Configuration
BIG-IP: Proxy Protocol enabled via iRule
NPIC: Proxy Protocol enabled by adding proxy-protocol: “true” in the ConfigMap during deployment
Issue
When the Proxy Protocol setting is added to the NPIC ConfigMap, the integration with BIG-IP breaks, and routing to pods through NPIC fails.
If this setting is removed, IngressLink functions normally: a Virtual Server is automatically created in the BIG-IP GUI, and responses through the NPIC path work correctly. However, in this case, direct requests to the BIG-IP Virtual Server IP fail.
In other words, while F5 CIS installation and IngressLink integration are partially functioning, access via the BIG-IP Virtual Server IP completely fails.
If anyone has experienced a similar issue or can offer insights into the cause and how to resolve it, your advice would be greatly appreciated.
Any debugging tips or relevant documentation would also be a great help.
Thank you.
Hello. Currently, the Proxy Protocol is enabled on the NGINX Plus Ingress Controller via a ConfigMap, and on the BIG-IP the Proxy Protocol is implemented through an iRule like the one shown in the picture.
When sending a request through the VIP (192.168.10.5), it returns an RST packet, and it appears that the BIG-IP side is terminating the connection.
Thanks you.
<BIG-IP iRule>
proxy Protocol Receiver iRule
# iRule used for F5 IngressLink
# Layer 4 irule since BIG-IP is passthroughwhen CLIENT_ACCEPTED {
set proxyheader "PROXY "
if {[IP::version] eq 4} {
append proxyheader "TCP4 "
append proxyheader "TCP6 "
append proxyheader “[IP::remote_addr] [IP::local_addr] [TCP::remote_port] [TCP::local_port]\r\n”
}when SERVER_CONNECTED {
TCP::respond $proxyheader
k get svc
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
coffee-svc ClusterIP 10.102.72.120 <none> 80/TCP 6d
nginx-ingress NodePort 10.111.109.219 <none> 80:31757/TCP,443:31116/TCP,8081:32198/TCP 6d16h
tea-svc ClusterIP 10.111.194.148 <none> 80/TCP 6d
curl --resolve cafe.example.com:31116:192.168.10.5 https://cafe.example.com:31116/coffee --insecure -v
* Added cafe.example.com:31116:192.168.10.5 to DNS cache
* Hostname cafe.example.com was found in DNS cache
* Trying 192.168.10.5:31116…
* connect to 192.168.10.5 port 31116 failed: 연결이 거부됨
* Failed to connect to cafe.example.com port 31116 after 2 ms: 연결이 거부됨
* Closing connection 0
curl: (7) Failed to connect to cafe.example.com port 31116 after 2 ms: 연결이 거부됨
