F5 APM Variable Assign agent
Hi All,
i am unable to understand the usage of Variable assign agent on F5 APM.
is there any simple way to understand
In simple terms, session variables are the mechanism that APM uses to store data about user’s sessions. This data has these properties:
1- It’s stored in BIG-IP’s high speed session database, which is the same one that is used to store information about sticky load balancing.
2- The data is string values that may include unicode characters. Array values are strings that are delimited by pipe | characters.
3- The names of the variables are loosely hierarchical, but do not follow any strict naming rules. You may set a session variable with any name you like. Here’s a reference with some of the common variables used.
4- Session variables are scoped per user. User sessions do not have access to each other’s session variables.
5- Session variables (usually tokens or passwords) may be encrypted in-memory so that a process dump will not contain sensitive data. The encryption key is a combination of a dynamic nonce used for that session and the BIG-IP’s master key.
The Variable Assign agent simply allows you to set one of these session variables to a custom value you choose.
Here’s a lab that talks about that VPE agent, how to use it, and why it’s there:
Thank you
