etc/init.d/network restart
Should this command just restart the management interface only? I ask as in VE it appears to effect other interfaces too. Thanks
Being a linux kernel based system,this will restart the network services i.e. all the network interfaces
Ajmal
Thanks Ajmal. So, if I wanted to reset just the management interface I guess something like 'ifdown eth0 && ifup eth0" would be better.
Posted By What Lies Beneath on 06/03/2013 03:12 AM
Yes that’s the command in case you need to bounce the interface in one go (use the down and up commands at the same time).
FYI… There are 2 options to run these command in a single line:
  • && - ifdown eth0 && ifup eth0 (This will run the 2nd command only if the output of 1st is “True”
  • Semicolon - ifdown eth0 ; ifup eth0 (This will run the 2nd command irrespective of the output of 1st command
Thanks. && is clearly safer.
