Error: SyntaxError: Unexpected token Error
dears,
I have an issue with one of my web applications, after users check on the tab under a specific URL this error appears ( Error: SyntaxError: Unexpected token ‘<’, “<html><hea”… is not valid JSON ) and after disable the policy from VS the error solved
@JRahm  may be able to help with a syntax question when he gets back from his PTO, if nobody else has answered first.
thanks,  @Leslie_Hubertus  appreciate your reply
Hi  @Amr_Ali  what type of policy is applied to the VS? If WAF policy, are you able to find in the devtools the ajax call and see if there is an WAF support id?
