Email Sender
Hi
I’ve a problem about email sender
This is my email
To: user@abc.com
Date: 07/02/2013 11:16 PM
Subject: 01070727:5: Pool member monitor status up.
How can I change “root@abc-01.com” into “abc-01@abc-01.com” ?
this is my alert config
alert BIGIP_MCPD_MCPDERR_POOL_MEMBER_MON_STATUS_UP {
snmptrap OID=“.1.3.6.1.4.1.3375.2.4.0.11”;
email toaddress=“user@abc.com”
fromaddress=“root”
body=“Pool Member monitor status UP”
thank you
From sol3667 .. If i changed fromaddress=“root” into fromaddress=“gtm01”
when email sent >> Does sender will change From: root@hostname.com into From: gtm01@hostname.com ?
Sorry I haven’t test system.
Thank you
teepan123,
From the sol in question:
Note: The BIG-IP system appends the local hostname to the configured fromaddress field to derive the FQDN for inclusion in the From: address.
Hope this helps,
N
Hi Nathan
And How about 11.x ? (ssmtp instead postfix)
my config is
mailhub=smtp.gmail.com:465
AuthUser=teepan123@gmail.com
AuthPass=xxxxxxxxxx
Hostname=
FromLineOverride=YES
UseTLS=YES
When I trigger alert
Email was sent but result is seem wrong >> [from: ] is still AuthUser not the one I set in alert.conf
to: teepan123@gmail.com
date: Wed, Jul 3, 2013 at 3:54 PM
subject: 01070640:5: Node /Common/test address 100.100.100.3 monitor status down. [ was unchecked for 0hr:0min:17sec ]
This is alert.conf
alert BIGIP_MCPD_MCPDERR_NODE_ADDRESS_MON_STATUS {
snmptrap OID=“.1.3.6.1.4.1.3375.2.4.0.12”;
email toaddress=“teepan123@gmail.com”
fromaddress=“bigip03-ve”
How to fix it?
Thank you
Try uncommenting out the “FromLineOverride=YES” line.
HTH,
N
After uncommenting the “FromLineOverride=YES” line.
When commenting the “FromLineOverride=YES” line.
difference in root word appear or not …and fromaddress in alert.conf still not shown
teepan123
I think if we use mailhub other than gmail (which must use AuthUser) everything will work out. -_-
