Hi All,
I’ve read the doco below but still a little unclear as to when a virtual server might redirect the request to an available node and/or pool member and when it might sent back a tcp reset upon the max connection limit being reached.
SOL9849: The BIG-IP sends a TCP RST packet when a pool member or node connection limit is reached
1/ Connection limit set on node
We are using source address persistence in this case so the client will hit the same node. Just wondering what happens to the client when they hit the same node again but it’s already reached it’s max connection limit. Will the client receive a tcp reset or will the virtual server try another available node from the pool?
2/ Connection limit set on a pool member
What if this time the max conn limit was set on the pool member instead. Same thing as 1/ here with source address persistence being used. Once the pool member’s max connection limit has been reached, will the client receive a tcp reset or will the virtual server try another available member from the pool?
Thanks.
Andy
