deleting a node
I have inherited LTM/GTM combo devices and they have a lot of legacy/obsolete configs. I am trying to clean up the configs. My questions is if I delete a node does it remove its reference from all the pools ? wish had a lab to test this .
If the node is currently a member of a pool, you’ll get an error like this:
Node address ‘/Common/dummy’ is referenced by a member of pool ‘/Common/empty_pool’.
Makes sense, so I would have to unassociate it from all the pools before deleting it.
thank you.
Correct.
