I have been using the content rewrite profile to rewrite requests from our externally available URL to the servername:port of the back end pool member. Everything has been working great with that config but I need to be able to use it when there is more than one member in the pool. For example, if a request is load balanced to server1 I need the content rewrite profile to do a rewrite to the servername:port, if it goes to memberserver2 then I need it to the same thing for that server. Is there a way to do that with the content rewrite profile or is there an iRule that can statisfiy this?
Thanks!
Hi @etherchannel01 ,
I have deployed this iRule to simulate your scenario of URL rewriting :
if { [HTTP::host] equals "shopping.asm.f5" } {
HTTP::header replace Host [LB::server addr]:[LB::server port]
and I got this Result on my lab :
you can see the host has been changed to the selected pool member and port.
> in your scenario you want the pool member-name:port , not pool member ip address:port
so try to use
[LB::server name]:[LB::server port] (instead of) [LB::server addr]:[LB::server port]
There are a lot of options with [LB::server] function
> may my iRule meets your Concern or give you a clue to find the optimal solution , I test it on my lab and it has given me the expected result accourding my lab scenario.
> If this available with you , I want to see how do you configure the Content rewrite profile , it just for adding to my knowledge.
