Client Certificate Authentication/Certificate in header PROBLEM
Hi everyone,
I have big problem with f5. In my application I authentication users by their cert. Authentication is required in specified URL. Bellow my iRule. I have configured Client SSL Profile and connected to VIP: every options default excluding:
Client Certificate: ignore
Frequency: once
Certificate Chain Traversal Depth 9
Trusted Certificate Authorities: My_CA
Advertised Certificate Authorities: None
Certificate Revocation List (CRL): My_CRL
When I open url: "/url/no_"1 I get prompt about client certificate. This is OK. But when I choose certificate and click “OK” f5 should add and send my client cert to the application in header. F5 don’t send this certificate. Header is blank. F5 add and send certificate in header after 2 redirection or when user two time refresh website. Cert should by always send in header. If header is blank application returns 401 (unauthorized).
Please help me, thank you
My irule in the order:
iRule1:
set host [string tolower [HTTP::host]]
if { $host eq "" }
set host [IP::local_addr]
STREAM::disable
when HTTP_RESPONSE {
 if { [HTTP::header value Content-Type] contains "text" and $host ne "" }
    STREAM::expression "@http://$host @https://$host@"
    STREAM::enable
 if {  [string tolower [HTTP::header Location]] starts_with "http://$host" }
    HTTP::header replace Location [string map -nocase "http://$host https://$host"
iRule2:
when CLIENTSSL_HANDSHAKE {
   set cur [SSL::sessionid]
   set ask [session lookup ssl $cur]
   if { $ask eq "" } {
     session add ssl [SSL::sessionid] [SSL::cert 0]
 when HTTP_REQUEST  {
   set id [SSL::sessionid]
   set the_cert [session lookup ssl $id]
   if { $the_cert != ""} {
     HTTP::header insert SSL_CLIENT_CERT [X509::whole $the_cert]
iRule3:
  if { [SSL::cert count] ==0 } {
  else {
    HTTP::release
 if { [HTTP::uri] starts_with "/url/no_1" or [HTTP::uri] starts_with "/url/no_2"  } {
    if {[SSL::cert count] == 0} {
    HTTP::collect
        SSL::authenticate always
        SSL::authenticate depth 9
        SSL::cert mode require
        SSL::renegotiate
  else {
Give this a shot. It’s also a combination of all of your rules, so you can replace all of them for this one:
when CLIENTSSL_CLIENTCERT {
    if { [SSL::cert count] < 1 } {
         if the client did not present a certificate - fail
        reject
         set a temporary cert variable here
        set clientcertdata [X509::whole [SSL::cert 0]]
    HTTP::release
     get host header and disable STREAM
    if { $host eq "" } {
    STREAM::disable
     private URI space requested and F5AUTH cookie does not exist - prompt for client certificate
    if { not ( [HTTP::uri] equals "/favicon.ico" ) and ( [HTTP::uri] starts_with "/private" ) and not ( [HTTP::cookie exists F5AUTH] ) } {
         invalidate SSL and renegotiate
        HTTP::collect
        SSL::session invalidate
        SSL::renegotiate
    } elseif { [HTTP::cookie exists F5AUTH] } {
         F5AUTH cookie exists - send HTTP header data
        if { [table lookup -subtable CERTDATA [HTTP::cookie value F5AUTH]] ne "" } {
             insert cert subject
            HTTP::header replace SSL-CLIENT-CERT [table lookup -subtable CERTDATA [HTTP::cookie value F5AUTH]]
when HTTP_REQUEST_SEND {
    clientside {
        if { ( [info exists clientcertdata] ) and not ( [HTTP::cookie exists F5AUTH] ) } {
             send first header
            HTTP::header replace SSL-CLIENT-CERT $clientcertdata
     process response payload with STREAM
    if { [HTTP::header value Content-Type] contains "text" and $host ne "" } {
        STREAM::enable
     rewrite the redirect Location header if it exists
    if { [string tolower [HTTP::header Location]] starts_with "http://$host" } {
        HTTP::header replace Location [string map -nocase "http://$host https://$host" [HTTP::header Location]]
     if the uniqueid variable is set - send the F5AUTH cookie to client
    if { [info exists clientcertdata] } {
         generate a GUID
        set uniqueid "_[string range [AES::key 256] 34 end]"
         insert the table entry
        table add -subtable CERTDATA $uniqueid $clientcertdata 3600
         send the cookie
        HTTP::header insert "Set-Cookie" "F5AUTH=$uniqueid; path=/; secure; HTTPOnly"
         unset the clientcertdata variable
        unset clientcertdata
The iRule sets a cookie and stores the cookie data in a session table entry to guarantee that a) it always exists, and b) the user doesn’t have to renegotiate SSL every time they attempt to access a private URI. You’ll need to modify the URI condition above for your private URI patterns.
Thank you very much for your help. It works.
