Clean Installation of F5OS-A on rSeries After Drive Erasure or Console Loss
Overview
This guide provides step-by-step instructions for performing a clean installation of F5OS-A on rSeries appliances using a USB flash drive. This method is typically used when the system is unrecoverable or when you need to start from factory defaults.
Prerequisites
  • Physical Access: You must have physical access to the appliance to connect a console cable and insert a USB flash drive.
  • USB Flash Drive: Minimum 8GB capacity. Note: The USB drive will be completely erased during the bootable drive creation process. Back up any existing data before proceeding
Console Configuration
  • Default Serial Console Settings:
  • Baud rate: 19200
  • Data bits: 8
  • Stop bits: 1
  • Parity: None
  • Flow control: None
Troubleshooting Console Issues: If you see scrambled output, verify your terminal emulator matches these settings. If issues persist, try changing the baud rate to 9600 (refer to K000133428 and K000138117).
  1. Software Requirements
    F5OS-A ISO Image: Download the correct F5OS-A ISO image from the F5 Downloads site.
    Security Note: The front-panel USB port is disabled by default for security purposes. You must enable it using the Always-On Management (AOM) menu before proceeding
  2. Enable the Front-Panel USB Port - AOM Menu Access
    a) Connect to the system via the console.
    b) Access the AOM menu by pressing Esc followed by (.
    c) In the AOM menu, type U to configure the USB port.
    d) Select 1 to enable the USB port.
    e) Type R to reset the host subsystem for the change to take effect.
  3. Create a Bootable USB Flash Drive
    a) Insert the USB flash drive into a USB port.
    b) Verify the USB device path before proceeding:
    lsblk /dev/sda
    c) On a Linux system, use the following command to write the ISO to the USB drive
        (replace  <iso-image> and /dev/sda as appropriate):
    dd if=<iso-image> of=/dev/sda bs=1M oflag=sync status=progress
    This process may take several minutes.
    Example:
    • dd if=/var/import/staging/F5OS-A-1.8.0-12345.R5R10.iso of=/dev/sda bs=1M oflag=sync status=progress
  4. Perform the Clean Installation
    a) Insert the bootable USB flash drive into the enabled front-panel USB port.
    b) Connect to the system via the console.
    c) Reboot the system.
    d) During boot, intercept the process by typing b at the BIOS setup screen.
    e) Select the USB flash drive as the boot device.
    f) From the installer menu, select “Install F5OS-A.” The installation will proceed automatically.
    g) After installation, the system will reboot. Remove the USB drive when prompted.
    h) The first boot may take 10-15 minutes.
  5. Post-Installation
    a) Configure management IP and license the system as required.
    b) If you continue to experience console issues, double-check your serial settings or refer to           K000133428.
  6. Alternative: PXE Boot (If USB Not Allowed)
    If your site does not allow USB drives, you can perform a clean install using a PXE server. This requires additional setup (DHCP, TFTP, HTTP) and is detailed in the official F5 documentation.
  7. Important Notes
a) A clean installation will erase all data and configurations on the appliance.
         b) If the system remains inaccessible after a clean install, hardware failure may be present and               an RMA may be required (K000150961).
         c) For drive erasure before RMA, see K000134775.
References
If you’ve encountered similar issues such as console access problems, drive failures, or challenges during a clean installation, please share your experience.
The Linux command in your guide:
writes the F5OS-A ISO image directly to a USB device in raw mode, creating a bootable USB.
Windows does not have a native dd command, but there are several equivalents.
1. Recommended (Windows GUI) – Rufus
This is the simplest and most commonly used tool for creating bootable USB drives in Windows.
Steps
1. Download and open Rufus.
2. Insert the USB drive.
3. In Device, select your USB drive.
4. Click SELECT and choose the F5OS-A ISO file.
5. Leave default settings (usually fine).
6. Click START.
Rufus will write the ISO to the USB in a way equivalent to the Linux dd process.
Why it’s preferred
• Very reliable for bootable media
• Shows progress and errors
• Prevents selecting the wrong disk
2. Command-line Equivalent – Win32 Disk Imager
This behaves very similarly to dd.
Steps
1. Install Win32 Disk Imager.
2. Insert USB drive.
3. Select the ISO file.
4. Choose the correct device (e.g., E:).
5. Click Write.
Internally this performs a raw block write, similar to dd.
3. True dd on Windows – Cygwin or Windows Subsystem for Linux
If you want the exact same command syntax, install WSL or Cygwin.
Example in WSL:
sudo dd if=F5OS-A-1.8.0.iso of=/dev/sdX bs=1M status=progress
Where /dev/sdX is the USB device.
