Change active volume for next boot.
Hello.
I need that curently active partition will be active for next reboot. How can I do this without rebooting device?
Screenshots attached.
have you tried switchboot command?
tnx a lot!
did’t know about that command.
welcome. actually, i just realized it works in v11 as well. :stuck_out_tongue:
sol5658: Overview of the switchboot utility
please be noted that it will reboot automatically in viprion platform.
sol9296: Changing the default boot image location on VIPRION platforms forces a reboot to the new boot location
Worked for me too. BIG-IP Virtual Edition 11.6.1. Thanks!
I had an issue where my VE lab would not shutdown and reload into a newly installed software image through the normal “activate” function. A bit more manual, but the switchboot command worked for me too. Thanks! v12.0.0 --> v12.1.3
