I’m a relative novice when it comes to the in’s and out’s of the LTM.
I have a business partner who needs me to host an Internet-facing Web server which connects to a backend application server. I’m running a STANDARD virtual server, using only HTTPS as the service port, and performing SSL off-loading.
The developers are telling me that when they hit the Web server through the LTM, they cannot retrieve the WSDL. However, when hitting the Web server directly, the WSDL can be retrieved. They are suggesting that the LTM is blocking/dropping access to the WSDL.
Can someone point me in a direction that may rectify this issue?
Thanks.
can you check the following:
under local traffic - virtual servers, check the following:
-there is a http profile attached -snat is set to automap
also, make sure that necessary routing is in place, under Network - routing
Thanks for the quick reply!
- I do not have an HTTP profile configured for the VS
- SNAT is set to Auto Map
Using ‘netstat -r’, the routes are present to get to the destination network where the application lives.
can you try to add the default http profile, and click update?
Thanks for the suggestion.
I updated the VS with the default HTTP profile but the results are still the same.
if you switch to advanced configuration on your virtual server, can you make sure that port translation and and address translation is ticked off?
also, make sure you have attached a valid certificate to the virtual server, and created a ssl client profile
I was just looking at that and, yes -- they are both selected “on” within the VS configuration.
good…and have you imported the certificate and attached it to a ssl client profile in the virtual server?
Yes. We use a domain wildcard certificate for most of our external-facing services. We’re not having issues accessing the front end Web services behind the LTM -- just retrieving the WSDL.
Thanks again for all your suggestions.
Use a software to capture the HTTP traffic, like httpwatch or fiddler. Check what is the behavior when going directly to the server, and when going via the F5.
The request for the WSDL should point to the F5, with the same IP and Port, otherwise that traffic will not be handled by the F5.
