bigpipe stderr/stdout
I noticed that a successful ‘b config sync’ outputs to stderr. Is this the expected behavior of bigpipe? I haven’t tested any other commands.
[admin@ltm02:Standby] ~ b config sync pull &> /dev/null
[admin@ltm02:Standby] ~ b config sync pull 1> /dev/null
Checking configuration on local system and peer system…
Peer’s IP address: 172.1.1.1
Saving active configuration…
Current configuration backed up to /var/local/ucs/cs_backup.ucs.
Product : BIG-IP
Version : 10.2.0
Hostname: UCS : ltm01.domain.com
System: ltm02.domain.com
Installing --shared-- configuration on host ltm02.domain.com
Installing configuration…
Post-processing…
Reading configuration from /config/low_profile_base.conf.
Reading configuration from /defaults/config_base.conf.
Reading configuration from /config/bigip_sys.conf.
Reading configuration from /config/bigip_base.conf.
Reading configuration from /usr/share/monitors/base_monitors.conf.
Reading configuration from /config/profile_base.conf.
Reading configuration from /config/daemon.conf.
Reading configuration from /config/bigip.conf.
Reading configuration from /config/bigip_local.conf.
Loading the configuration …
[admin@ltm02:Standby] ~ b config sync pull 2> /dev/null
Configsync Mode: Pull
Saving temporary UCS on peer…
Downloading UCS from peer…
After reproducing the stderr output I noticed there was also some info being written to stdout. It appears that this was done to separate the events that occur on the peer (stdout) from those on the unit the pull is being executed from (stderr). I ran it both ways and this is what I got:
[root@test-ltm:Active] ~ b config sync pull 2> /dev/null
[root@test-ltm:Active] ~ b config sync pull 1> /dev/null
Installing full configuration on host test-ltm
Installing…
Installing WAM database from UCS…
Reloading configuration… It may take a few minutes…
Loading WAM configuration…
DB version is 9
Patching WAM 9.4.2 Database
Reloading WA predefined policies. .. Done.
Reading configuration from /usr/bin/monitors/builtins/base_monitors.conf.
