BIG-IP : completely delete data-group
F5 BIG-IP 11.4.1 Build 635.0 Hotfix HF2 LTM VE ESXi
via admin browser I perform following steps :
Main > Local Traffic > iRules > Data Group List > select data group > delete "my-data-group"
Main > System > File Management > Data Group File List > select data-group file > delete "my-data-group"
Then ssh to f5-device server and navigate to this dir :
/config/filestore/files_d/Common_d/data_group_d/
I expect to not find any file with name
my-data-group
… but instead I see :
-rw-r--r-- 1 root   apache      62 Sep  8 22:25 :Common:my-data-group_64015_18
For some reason BIG-IP is retaining an underlying data-group file of same name as the external data-group & associated file that I deleted.
  1. Why is this ?
  2. Can I safely delete this file ?
BaltoStar
Don’t delete anything out of the Filestore directly without being told by support. Tis bad juju!
Check what you have here: tmsh list ltm data-group external
that will see whats actually still in existence.
