I have configured URI based parameter selective learning (Manual Policy Learning). I get a lot of parameters with very simular names all violating the same signatures. I thought if I configured a wildcard matching the paramters and deleted the learning suggestions, it would make the learning suggestions again on the new wildcard parameter. - but I cant get this to work ![]()
Say I have (learning suggestions):
- Para1 violating signature 200012345
- Para2 violating signature 200012345
- Para3 violating signature 200012345
- Para4 violating signature 200012345
If I delete the above and add a wildcard of para? - If I clear the original learning suggestions and wait.
I am expecting this to happen - Learning suggestion on wildcard on parameter of Para? to disable signature 200012345
but I get
- Para4 violating signature 200012345 (same again)
So I am thinking, of three possibilities
- This is correct behaviour
- My Wildcard is not matching as I got the syntax wrong
- I delete the learning suggestions and add the signature override manually and this will stop the specific parameter learning suggestions
I dont know what the expected behaviour is, I thought this would work, but maybe I have to add the signatures to the new wildcard parameter manually.
Kind Regards GM
