I set as follows at the APM.
At the end of this configuration is loaded OTP Verify the policy as follows: ;
SSL VPN to enter your username and password,
If you enter OTP code received by SMS message
It will fail to log in.
There is a well Hsien not using the OTP Verify menus,
What should I do?
You need to add “OTP Verify” after OTP Logon Page and move your Expression “OTP Auth passed” to that box.
Hello,
Why not using the OTP Verify block available in the VPE after your last Login Page ?
You should have a look at the logs in the report and check what is the exact expression of OTP Auth has Passed.
But definitely, the expression in the branch of the last login page seems to fail because there is no check for session.logon.last.password against session.user.otp.pw
