I running an LDAP query in a policy that is performing
return [mcget {session.ldap.last.attr.userPrincipalName}]
I know this is working for known UPNs, but I’m not catching the exceptions and taking the fallback path.
I’ve noticed that even upon query failure the policy is not using the fallback path even when the last.errmsg is “No such object” and the query result is “0” - the policy continues to the variable assign, which it should only perform when a UPN is matched.
Any suggestions?
Hello.
In your ldap query validate the following point:
in your ldap query object you add the following attribute "
userPrincipalName
", in "
Required Attributes (optional)
second point, in branch rules, be sure that you modified expression from:
Expression: User is a member of CN=MY_GROUP, CN=USERS, CN=MY_DOMAIN
to
Expression: LDAP Query has Passed
Keep me in touch.
regards
Ok - I shifted the logic. The input for the query is taken care of in the filter.
So for my success branch I use
expr { [mcget {session.ldap.last.queryresult}] == 1 }
and getting the expected results:
LDAP query is good based on valid filter input = success
LDAP query fails based on input not found (no such object) = session.ldap.last.queryresult = 0 and fallback path is taken.
normally you see error message generated for LDAP in session.ldap.last.errmsg (ex: aad2a221.ldap.last.errmsg) it is useful for troubleshooting.
You can also activate “Show Extended Error” in your ldap query.
you will see the error generated by ldap…
keep me in touch
Yeah - I got so used to advanced query I forgot all about the built in basics.
