APM expression
I get a syntax error but coyldnt figure out what I did wrong…ver 11.6 HF6 expr { [string tolower [mcget {session.logon.last.logonname}]] contains “@domain.name.com” } the log shows: Rule evaluation failed with error: syntax error in expression…
Probably instead of:
You should use:
expr { [string tolower [mcget {session.logon.last.logonname}]] contains "@domain.name.com" }
Note the difference in double-quote characters.
