Hi all
I am trying to get the apm module working for adfs and have about 90 % thier I used this article for ideas
https://devcentral.f5.com/weblogs/g…-the.aspxv
the Part where I am stuck on and need help from the gurus is when using the vpe to create the apm policy thie artcle states
An AD query and simple iRule is used to provide single-url OWA access for both on-premise and Office365 Exchange users.An AD query and simple iRule is used to provide single-url OWA access for both on-premise and Office365 Exchange users.
So I have the ad query setup to search all members of a group but he states the irule he inserted in the variable assign portion. How can I import this irule into the variable assign.
thanks in advance
Hey Sam,
In addition to Michael’s comments, the ADQuery object will query a user’s Active Directory attribute. In this case I used the ‘Target Address’ attribute. You could also query the ‘HomeMDB’ attribute which should be empty if the end-user’s mailbox is with O365. If appropriate, I assigned a session variable to use in the iRule which will perform an HTTP redirect. As Michael said, the iRule is associated with the virtual server.
Hey Sam,
Thanks guys its working !!
