I’d like to use the value of a dropdown list set in a specific section (eg Environment) to build the default value of another choice in another section (eg Profile).
How can i reference the first value ?
Thanks in advance.
Thanks in advance.
The following two posts seem to indicate that it is not possible but as they are from 2013, i was wondering if there was any changes around that :
DevCentral - An F5 Technical Community DevCentral - An F5 Technical Community
