Alias entry under wide IP
Hi Team,
One quick question, suppose we add an alias under GTM wide IP. shall we need to update LTM VIP also which is behind the gtm pool with client profile certificate? means certificate should also require this alias name in its san entry?
Thanks,
Neha
it’s usually not needed.
in short, the hostnames in ssl certificate only need to match to the hostname of the http layer request.
client’s ssl layer will automatically uses that http layer hostname for tls sni request field.
also, http and ssl/tls layer doesnt care about dns cname things.
so if the hostname in http(s)://<hostname>/… doesnt change, then you dont need to update the ssl cert.
Thankyou!!
from the Host name here are we referring URL/FQDN name we have A record for?
basically yes.
e.g. eventhough the url’s fqdn is cnamed thousands times, the client’s http and ssl/tls layer doesnt care about it.
these layers only read resulted ip address.
Thanks @zamroni777
But it didn’t work. we updated Alias but still its giving certificate error. so seems San name needed in Cert.
@NGupta23 If you are using different URLS in an application, you must add the FQDN in SAN or use one wild card certificate for it.
that means there is hostname change in the your app’s http layer.
if it’s browser based, you can see the http transactions network tab of browser developer console (press F12).
the principle remains that http and tls/ssl layers doesn’t care about cname, even it happens thousands time for a hostname.
see below for www.f5.com as example that cn in the cert only contains www.f5.com eventhough the hostname is cnamed.
