AFM deny log level
Hello,
not sure if it possible, we have AFM and high speed logging forwarding deny logs to a syslog server. We seen that the syslog level is local0.info.
Is it possible to change it to another level, like “warning”
Thanks.
Hi Man_Yau. Need more information, please.
Do you mean, you only want logs with level ‘warning’ (and lower) to be sent to the syslog server?    Is local0.info being set within an iRule?
Have you checked the configuration of the Log Filter? (System > Logs > Configuration > Log Filters). Specifically, the Severity setting.
The severity level that you select includes all of the severity levels that display above your selection in the list. For example, if you select
Emergency, the system publishes only emergency messages to the log.
If you select Critical, the system publishes critical, alert, and emergency-level messages in the log.
Hi Seattle2k,
local0.info is what we seen in our syslog server and we dont have an irule for setting log level, so i assume it is standard by F5. I’m trying to see if i got it higher to warning level.
I have just checked that settings, but which is source should i select? There is too many that i can choose from, but with the log filers, are we able to change the log level from info to warning?
I think you are confusing terminology.
local0.info is the “syslog facility”, not the level.
As for ‘source’,  select the system processes from which messages will be sent to the log.
