About script
Hello,
I want to make a script that sends alerts to /var/log/ltm every minute when the pool is not up.
Here is the script I designed:
modify script pool_script {
    app-service none
    definition {
        set errorcode [catch {exec tmsh show ltm pool | grep Ltm | awk {{ print $(NF-2) }}} result]
        set result [split $result "\n"]
        tmsh::log_dest file
        tmsh::log_level debug
        foreach i $result {
            set pool "[lindex $i 1]"
            if { [tmsh::show ltm pool] contains "Availability           : available" } then {
                tmsh::log debug "F5 Pool:${pool} Status -> Not available."
    description none
    events none
I thought it worked, but then I realized that the log only appears when the first pool doesn’t start as it should.
Please tell me how to change my script…
Any help is appreciate.
Hi Michaelyang,
on a quick view: You are not passing $pool to the “tmsh::show ltm virtual” command…
Cheers, Kai
Hi Kai_Wike,
Sorry, I sent the wrong one
I’ve updated it…
As i said… you are not passing the $pool variable into the the “tmsh::show ltm virtual” command. In this case you check if a single pool of all your pools is available. It should be “tmsh::show ltm virtual $pool”
Beside of this the [exec] part can be avoided… Give me a sec to give you a quick coding how to access and enumerate LTM configurations within TMSH scripts…
Cheers, Kai
Hi Kai_Wike,
I’ve updated it again…
Thank you
Hi MIchaelyang,
check the iCall script below to get a picture how to LTM configs could be enumerated with foreach loops.  No need to [exec] native BASH commands… :wink:
sys icall handler periodic check_pool_state {
    interval 120
    script check_pool_state
sys icall script check_pool_state {
   app-service none
   definition {
		tmsh::log_dest file
		foreach temp(pool_config) [tmsh::get_config /ltm pool] {
			set temp(pool_name) [tmsh::get_name $temp(pool_config)]
			if { [tmsh::show /ltm pool $temp(pool_name)] contains "Availability           : available" } then {
				# Everything is fine...
				tmsh::log debug "Pool Check: $temp(pool_name) is unhealthy"
   description none
   events none
Cheers, Kai
Still the same problem. Check the script I’ve just posted. During the foreach loop it passes the currently processed $temp(pool_name) to the [tmsh::show] command, so that you analyse the state of the just processed pool. If you dont pass the pool name to the show command, then you would analyse all pools at the same time.
Cheers, Kai
Hi Kai_Wike,
Thanks for your help.
I’ll look into it..
You are welcome.
I pretty much like to see you enjoying iCall. You truly deserve Kudos for your creativity :wink:
Cheers, Kai
