4096 SSL keys
I implemented a cert/key to my LTM 9.4.6 and when I try to create a SSL profile it shows: 4096 bit keys are not supported
Is this mean that I have a problem?
I guess 4096 key are not supported and I need to downgrade my cert to 2048?
How can I check what kind of keys are supported on my box?
Martin
