1 VIP / any ports used for both HTTP and HTTPS, possible?
Hello,
We would like to use the same VIPs and DNS names for both encrypted/non encrypted traffic, with this idea:
•If F5 LTM receives HTTP traffic (on any port), it should not encrypt. •If F5 LTM receives SSL traffic (on any port), it should encrypt.
if encrypted on port x, then send encyrpted on port x if non encrypted on port x, then send non encyrpted on port x.
The pool is the same for both cases
There is an option to allow non-SSL traffic on client ssl profile but this option is bot there for server ssl profile, so maybe there exist an iRule for this?
Thanks for your help!
The only way I can think to do that would be rather kludgy.
Have a TCP passthru virtual that selected the appropriate virtual based on something in the data stream, so you’d have to do a TCP capture. Here’s one way to do it (ripped of the binary scan from another dev central post: DevCentral - An F5 Technical Community
Virtuals (the content switch, and two bogus IP’d ones…don’t have to be bogus, but don’t need to be exposed at all):
ltm virtual multiproto-test-passthru-any {
    destination 10.0.0.181:any
    ip-protocol tcp
    mask 255.255.255.255
    profiles {
        tcp { }
    rules {
        multi-protocol-rule
    source 0.0.0.0/0
    translate-port disabled
    vs-index 17
ltm virtual multiproto-test-any {
    destination 1.1.1.2:any
    ip-protocol tcp
    pool multiproto-test-any
    profiles {
        tcp { }
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 15
ltm virtual multiproto-test-ssl-any {
    destination 1.1.1.1:any
    ip-protocol tcp
    profiles {
        clientssl {
            context clientside
        serverssl-insecure-compatible {
            context serverside
        tcp { }
    source 0.0.0.0/0
        type automap
    vs-index 14
The iRule:
ltm rule multi-protocol-rule {
    when CLIENT_ACCEPTED {
      TCP::collect 15
    when CLIENT_DATA {
        binary scan [TCP::payload 15] H12 data
        if { ( $data starts_with "1603") } {
            log local0. "$data"
            log local0. "[TCP::payload]"
        TCP::release
This worked for me. Not sure why you’d wanna do that, but if you do …
what about this?
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:0
    ip-protocol tcp
    pool foo
    profiles {
        http { }
        myclientssl {
            context clientside
        serverssl {
            context serverside
        tcp { }
    rules {
        qux
    source 0.0.0.0/0
        type automap
    vs-index 14
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:0 {
            address 200.200.200.101
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm profile client-ssl myclientssl
ltm profile client-ssl myclientssl {
    allow-non-ssl enabled
    app-service none
    cert-key-chain {
        default {
            cert default.crt
            key default.key
    defaults-from clientssl
    inherit-certkeychain true
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
    when CLIENTSSL_HANDSHAKE {
  set is_ssl 1
  if { not([info exists is_ssl]) } {
    SSL::disable serverside
 test
[root@centos1 ~] curl -I http://172.28.24.10/
HTTP/1.1 200 OK
Date: Mon, 17 Nov 2014 03:59:07 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Sun, 09 Feb 2014 08:39:51 GMT
ETag: "41879c-59-2a9c23c0"
Accept-Ranges: bytes
Content-Length: 89
Content-Type: text/html; charset=UTF-8
[root@centos1 ~] curl -Ik https://172.28.24.10/
HTTP/1.1 200 OK
Date: Mon, 17 Nov 2014 03:59:13 GMT
Content-Length: 89
thanks both of you, nitass solution is neater, i tested and it works, thanks a lot!
