tacticman_89870
16 years agopost logon sequence
Hi all,
i want to know if it's possible to move pre logon sequence after login/password prompt.
At the moment we checked corp pcs before logon, the problem is about protected workspace and activex installation. so i want the use to click on network access and get a inspection before it.
Can you give me some advices ?
- Mike_61719
Cirrus
Not possible, install the .MSI installer package. Sorry :/ - tacticman_89870
OK so is it possible to configure listeners using differents URI on the firepass one which doesn't inspect the PC before logon and the other one which is the same as today ? - Mike_61719
Cirrus
You mean URI's or total new host?
If I am understanding you correctly, a few sample scenario's.
FP.com
FP.com/nopws
FP.com/support
The above includes URI's. You can then, in the main prelogon sequence set a straight authentication for the URI. It is like session.uri == nowps and then go to fallback of logon.
FP2.com
FP3.com
Firepass.com
If you are using a completely different IP and host name the process is similar. In the main prelogon sequence you change it to session.host == 192.168.1.1 or something. You can use the FQDN as well. Just set the main prelogon sequence to look for that prior to doing any other checks. - tacticman_89870
Hi thank you for your reply.
yes i mean same host or web service but different URI.
Can you explain more how to do this ? I think that :
- you have to create new URI-base customization
- then you go to the active PRE-LOGON SEQUENCE
- here i Have registry check --> ANtivirus check --> firewall check
- how can I add my variable with client using the new URI just created ?
THank you - Mike_61719
Cirrus
You log onto the Firepass
Click on Customization -> URI Based customization -> Create URI (Form Based)
Go to your Pre-logon sequence, at the start of the sequence enter in a custom rule
session.network.server.land_uri = "BLABLABLA"
Proceed to edit your Pre-logon sequence as normal.
You can then go to Firepass.com/BLABLABLA
