Troubeshooting website connection
We are using BIG-IP with LTM and SSLO to inspect web application traffic. What are good troubleshooting techniques to go through the device when a website doesn't establish connection? We would want to eliminate the F5 from being the cause and attempt to narrow down where the traffic is getting broken if possible.
By "these modules", I'm assuming you mean "the SSL Orchestrator module". We do have a deployment guide over here that is very comprehensive:
https://clouddocs.f5.com/sslo-deployment-guide/sslo-11/
Reading the deployment guide will give you a good understanding of how the SSL Orchestrator module works and how to set it up.
SWG and SSLO essentially use the same architecture but the setup is somewhat different, as you've no doubt found. We generally recommend using SSLO to perform the setup, then using "SWG as a Service" to perform custom authentication, auditing, or authorization logic as needed. That is covered here:
https://clouddocs.f5.com/sslo-deployment-guide/sslo-11/chapter3/page3.06.html
- Lucas_Thompson
Employee
Network troubleshooting is usually easiest when you break down the problem into layers. We do have a troubleshooting guide for SSL Orchestrator over here:
https://clouddocs.f5.com/sslo-troubleshooting-guide/troubleshooting.html#data-plane
That link has a flowchart. Each item on the flowchart has information about how it works and what evidence to get to prove that it's working. You should probably start reading in that area to get an understanding of what approaches might be best for your environment.
- tstott707
Thank you for the attachment and explanation. We deployed the SSLO and rarely have to make the changes with that module when websites have issues. We do run LTM using iRules and Data Group along with SWG and website bypassing when needed. Is there another article that walks through a checklist when you are implementing these modules in the environment.
- Lucas_Thompson
Employee
usually i use tcpdump to analysze the ssl and http layer.
for encrypted traffic, add --f5 ssl option:
https://my.f5.com/manage/s/article/K31793632- tstott707
Thanks Zamroni777. Will add this to the troubleshooting steps as well
