_Dmi_'s avatar
_Dmi_
Nov 17, 2023
pool selection
Hi, is it poossible to implement irule logic below?
By default traffic select Pool1, but it select Pool2 if online pool members of Pool1 below two. If all pool members became available in Pool1, traffic will continue select Pool2.
    • _Dmi_'s avatar
      _Dmi_
      I cant use it. The full scenario is
      By default traffic select Pool1, but it select Pool2 if online pool members of Pool1 below two. If all pool members became available in Pool1, traffic will continue select Pool2. But then online pool members of Pool2 below two, traffic must come back to Pool1.
  • I think the iRule below fill meet your requirements.
    when CLIENT_ACCEPTED {
        set pri_pool "/Common/pool_a"
        set sec_pool "/Common/pool_b"
        if {[table lookup active_pool] ne ""} {
            if { [active_members [table lookup active_pool]] >= 2 } {
            elseif { $active_pool eq $pri_pool } {
                table replace active_pool $sec_pool indefinite
            else {
                table replace active_pool $pri_pool indefinite
        else {
            table set active_pool $pri_pool indefinite
        pool [table lookup active_pool]
    Have fun,
         --Niels
