iRule to send syslog messages to a remote server over TCP instead of UDP?
Hi all!
Do you konw if it is possilbe to send syslog messages from an iRule to a remote syslog server over TCP instead of UDP protocol? The goal is to be able to send longer/larger syslog messages.
Thanks!
Hi SMilanic ,
You don´t need an irule to send Syslog over the TCP Protocol, you can use Remote High-Speed Logging,
Follow this guide to configure HSL:
Hope it works
- SMilanic
Cirrus
Hello Sebastiansierra,
Thank you for your answer!
We need iRules to log some additional stuff, such as client certificates for debugging, etc. So from the top of my head I am not 100% sure, that we can direct logs from na iRule to local0. and (then) send it to a remote HSL destination. However, I think we could use HSL from an iRule, if I remember correctly.
I'll look into it. Thanks!
