venkatraman01
Dec 04, 2023Irule for inserting header for Google third party cookie deprecation
Hi Guys - Google is starting to deprecate support for third party cookies starting January 2024. As a temp solution they are asking all impacted customers to insert a http header with a token value. Can anyone help me with an irule that will insert a header in the http response.
The requirement is to add the below header in the http response through an irule:
Origin-Trial: TOKEN_GOES_HERE
Thanks for your help.
Sort By
you can use examples from
https://clouddocs.f5.com/api/irules/HTTP__header.html
