Deploy BIG-IP in AWS with HA across AZ’s - without using EIP’s
Background:
The CloudFormation templates that are provided and supported by F5 are an excellent resource for customers to deploy BIG-IP VE in AWS. Along with these templates, documentation guidi...
Published Feb 21, 2019
Version 1.0MichaelOLeary
Employee
Joined May 15, 2019
MichaelOLeary
Employee
Joined May 15, 2019
MichaelOLeary
Feb 22, 2019Employee
Hi Rafael, I deployed this template from F5's supported sample templates. I recommend doing the same. The template deployment configures default routes into a LOCAL_ONLY partition on each device, so that this default route for a device does not sync to the paired device.
