Deploy BIG-IP in AWS with HA across AZ’s - without using EIP’s
Background:
The CloudFormation templates that are provided and supported by F5 are an excellent resource for customers to deploy BIG-IP VE in AWS. Along with these templates, documentation guidi...
Published Feb 21, 2019
Version 1.0MichaelOLeary
Employee
Joined May 15, 2019
MichaelOLeary
Employee
Joined May 15, 2019
MichaelOLeary
Feb 21, 2019Employee
Hi Sebastian, yes - but you have to use a Transit Gateway to route between your VPCs. Transit Gateways were released in late 2018, and they will allow you to route between multiple VPCs. Prior to this, you needed to manage VPC peering relationships individually, and these peering relationships did not allow you to route a non-VPC IP range. (The other option prior to the release of Transit Gateways was to build IPSec VPN connections yourself between VPCs and I have not covered that here).
