Configure the F5 BIG-IP as an Explicit Forward Web Proxy Using LTM
In a previous article, I provided a guide on using F5's Access Policy Manager (APM) and Secure Web Gateway (SWG) to provide forward web proxy services. While that guide was for organizations that are looking to provide secure internet access for their internal users, URL filtering as well as securing against both inbound and outbound malware, this guide will use only F5's Local Traffic Manager to allow internal clients external internet access.
This week I was working with F5's very talented professional services team and we were presented with a requirement to allow workstation agents internet access to known secure sites to provide logs and analytics. Of course, this capability can be used to meet a number of other use cases, this was a real-world use case I wanted to share. So with that, let's get to it!
Creating a DNS Resolver
- Navigate to Network > DNS Resolvers > click Create
- Name: DemoDNSResolver
- Leave all other settings at their defaults and click Finished
- Click the newly created DNS resolver object
- Click Forward Zones
- Click Add
In this use case, we will be forwarding all requests to this DNS resolver.
- Name: .
- Address: 8.8.8.8
Note: Please use the correct DNS server for your use case.
- Service Port: 53
- Click Add and Finished
Creating a Network Tunnel
- Navigate to Network > Tunnels > Tunnel List > click Create
- Name: DemoTunnel
- Profile: tcp-forward
- Leave all other settings default and click Finished
Create an http Profile
- Navigate to Local Traffic > Profiles > Services > HTTP > click Create
- Name: DemoExplicitHTTP
- Proxy Mode: Explicit
- Parent Profile: http-explict
- Scroll until you reach Explicit Proxy settings.
- DNS Resolver: DemoDNSResolver
- Tunnel Name: DemoTunnel
Create an Explicit Proxy Virtual Server
- Navigate to Local Traffic > Virtual Servers > click Create
- Name: explicit_proxy_vs
- Type: Standard
- Destination Address/Mask: 10.1.20.254
Note: This must be an IP address the internal clients can reach.
- Service Port: 8080
- Protocol: TCP
Note: This use case was for TCP traffic directed at known hosts on the internet. If you require other protocols or all, select the correct option for your use case from the drop-down menu.
- Protocol Profile (Client): f5-tcp-progressive
- Protocol Profile (Server): f5-tcp-wan
- HTTP Profile: DemoExplicitHTTP
- VLAN and Tunnel Traffic Enabled on: Internal
- Source Address Translation: Auto Map
- Leave all other settings at their defaults and click Finish.
Create a Fast L4 Profile
- Navigate to Local Traffic > Profiles: Protocol: Fast L4 > click Create
- Name: demo_fastl4
- Parent Profile: fastL4
- Enable Loose Initiation and Loose Close as shown in the screenshot below.
- Click Finished
Create a Wild Card Virtual Server
In order to catch and forward all traffic to the BIG-IP's default gateway, we will create a virtual server to accept traffic from our explicit proxy virtual server created in the previous steps.
- Navigate to Local Traffic > Virtual Servers > Virtual Server List > click Create
- Name: wildcard_VS
- Type: Forwarding (IP)
- Source Address: 0.0.0.0/0
- Destination Address: 0.0.0.0/0
- Protocol: *All Protocols
- Service Port: 0 *All Ports
- Protocol Profile: demo_fastl4
- VLAN and Tunnel Traffic: Enabled on...DemoTunnel
- Leave all other settings at their defaults and click Finished.
Testing and Validation
- Navigate to a workstation on your internal network.
- Launch Internet Explorer or the browser of your preference.
- Modify the proxy settings to reflect the explicit_proxy_VS created in previous steps.
- Attempt to access several sites and validate you are able to reach them.
- Whether successful or unsuccessful, navigate to Local Traffic > Virtual Servers > Virtual Server List > click the Statistics tab.
- Validate traffic is hitting both of the virtual servers created above.
- If it is not, for troubleshooting purposes only configure to the virtual servers to accept traffic on All VLANs and Tunnels as well as useful tools such as curl and tcpdump.
You have now successfully configured your F5 BIG-IP to act as an explicit forward web proxy using LTM only. As stated above, this use case is not meant to fulfill all forward proxy use cases. If URL filtering and malware protection are required, APM and SWG integration should be considered. Until next time!
34 Comments
- SV2022
Cirrus
irule is not working ..i mapped the irule with ip deatils that should be blocked while accessing the internet with explicit proxy VS... but still i could see the traffic is not hitting the irule both in stats/logs..
if { [IP::addr [getfield [IP::client_addr] "%" 1] equals "100.76.0.0/16"] } {
reject
}. - MacOA
So, I know this article is a bit old, but two questions:
1) If I have a 0.0.0.0/0 all port VS, it'll also match for any VS that has any other IP, but not that explicit port defined, correct? Since the source of the forwarded traffic will be the F5 tunnel, could I just allow that as the range? I'd rather not "capture" traffic otherwise destined for a specific VIP/VS, but doesn't happen to have the port being requested defined for the other VSs.
2)In the case of lookups, we need if it's not one of two specific domains, to just route to a specific pool as opposed to the wildcard IP forwarder. Today I do that successfully to the pool, but for all requests, including the two domains that when we switch proxy providers/applications those domains will fail so I'd like to handle those via the F5 forwader.
I appreciate anyone's thoughts.
Tagging original author Steve_LyonsThanks,
Pat Gasior
Sam_D_the reason the wildcard VS is necessary is because that is what creates the forward proxy tunnel between the BIG-IP and the destination that you are trying to reach through the forward proxy. If you didn't have this you wouldn't be able to dynamically configure the destination the way the wildcard VS does. I'm also glad that the article did help sort out the confussion you had on priority of VS.
- Sam_D_
Altostratus
Paulius thanks for your nice tips! That tech article really explains what confused me 😀
BTW, it'll be really appreciated if you could shed light on why we need a wildcard VS in addition to the explicit proxy VS. How do these two VSs work together to serve the forward proxying purpose?
Sam_D_ based on the following article I believe they would technically conflict with each other so I think the index ID would most likely cause traffic to go to the previously existing VS first rather than a new one that listens on the specific interface/vlan/tunnel.
- Sam_D_
Altostratus
I'm wondering how such a newly created wildcard VS with settings listed below will affect our existing Virtual Servers that were created with BigIP as a Reverse-Proxy with All VLANs and Tunnuels for "VLAN and Tunnel Traffic"?
- Yonatan_Talmor
I had to struggle with this one for hours
Finally it succeeded to work, but it took an extra setting: only after I added the 'route domain' directive in HTTP profile attached to the explicit proxy VIRT.
that is, I suppse, due to the multi route domain design in my env.now everything just works, also for HTTPS traaffic.
Thank you
Steve_LyonsBased on this article it seems like this forward proxy configuration is suppose to work for HTTP requests to the forward proxy but does this work for HTTPS requests to the forward proxy? Currently when I attempt to utilize the forward proxy for HTTPS communication I receive a "HTTP/1.0 503 Service Unavailable" in the browser and in the tcpdump I see "Connect failed[!http]" which makes me believe this type of forward proxy does not support HTTPS communication. I am seeing "CONNECT <redactid FQDN>:443 HTTP/1.1" and "Host: <redactid FQDN>:443" in the initial request so the F5 is definitely seeing the appropriate pieces of information but it continues to fail.
- Jiwook
Erik_Roeckers Hi I have some questions.
I try to configure forward proxy on LTM following this article.
But I Can't reach outside Internet but Can on F5 explicit_proxy_vs
At virtual Server Statistics, I can see wildcard_vs packet 'zero'.
I assume that my packet can't pass through F5 LTM.
It's enabled port translation on expicit_proxy_vs but there is not ' port translation' options on wildcard ip forwarding vs...:(
- Erik_Roeckers
Employee
To get this to work I needed to enable port translation in the wildcard IP forwarding virtual server. Without that it was sending traffic out to the web server on port 8080 instead of port 443 or 80. This was on BIG-IP version 15.1.
