python bigsuds - Device Certificate Info
Problem this snippet solves:
This python bigsuds script prints device certificate information from multiple devices specified as arguments. The script accepts multiple hostnames or IP addresses and can be passed from stdin.
How to use this snippet:
Single host
cert-device.py <username> <hostname>
Multiple hosts
cert-device.py <username> <hostname1> <hostname2>
Pass from File (Linux)
cat bigip-hosts | xargs cert-device.py <username>
Code :
#!/usr/bin/env python __author__ = 'buzzsurfr' __version__ = '0.1' def get_device_certificate(api): ''' Gets device certificate information from multiple F5 BIG-IP devices. Prototype dict get_device_certificate( BIGIP.bigip api, ); Parameters api of type BIGIP.bigip contains the established connection. Return Type dict containing the certificate properties. ''' return api.Management.KeyCertificate.get_certificate_list_v2('MANAGEMENT_MODE_WEBSERVER')[0]['certificate'] # Standard Library import sys import re # Related Third-Party import getpass # Local Application/Library Specific import bigsuds if len(sys.argv) < 3: print "\n\n\tUsage: %s user host ..." % sys.argv[0] sys.exit() # Get login password from CLI userpass = getpass.getpass() # Store results in variables for all hosts as dict result = {} # Iterate over hosts for host in sys.argv[2:]: # Connect to BIG-IP api = bigsuds.BIGIP(host, sys.argv[1], userpass) api = api.with_session_id() result[host] = get_device_certificate(api) # Get console output column widths space = 2 columns = {} columns['host'] = max([len(host) for host in result]) columns['subject'] = max([len(cert['subject']['common_name']) for cert in result.values()]) columns['issuer'] = max([len(cert['issuer']['common_name']) for cert in result.values()]) columns['bit_length'] = 4 columns['expiration_string'] = max([len(cert['expiration_string']) for cert in result.values()]) print_string = "%-"+str(columns['host'])+"s"+(' '*space)+\ "%-"+str(columns['subject'])+"s"+(' '*space)+\ "%-"+str(columns['issuer'])+"s"+(' '*space)+\ "%"+str(columns['bit_length'])+"s"+(' '*space)+\ "%-"+str(columns['expiration_string'])+"s" # Output to console print print_string % ("Host", "Subject", "Issuer", "Bits", "Expiration Date") print print_string % ('='*columns['host'], '='*columns['subject'], '='*columns['issuer'], '====', '='*columns['expiration_string']) for host, certificate in result.iteritems(): print print_string % (host, certificate['subject']['common_name'], certificate['issuer']['common_name'], str(certificate['bit_length']), certificate['expiration_string'])
Tested this on version:
11.5Updated Jun 06, 2023
Version 2.0
