IF-MAP Secure Web Gateway for 11.5
Code :
67235
Tested this on version:
12.0Published Mar 11, 2015
Version 1.0Fred_Slater_856
Historic F5 Account
Joined May 02, 2012
7 Comments
- JC_47645
Is there an older version of this iapp that is compatible with v11.6.1? Or does anyone have any documentation that shows how to manually configure what this iapp does?
- AceDawg1
Got this working on 12.1.1.
- AceDawg1
Same error message with 11.5.4 HF6. Any updates on this?
- RLU5
Altostratus
I got the same error with v11.6.0 HF6
- kohli9harjeev
I tried to use this iapp on 11.6.1 but it shows an error
The requested customization_group (/Common/IFmap.app/IFmap_apm_HTTP_401_response_ag) was not found.
Is it not compatible with 11.6.1?
Regards
- mikeshimkus_111Historic F5 AccountHi pkwilly, thanks for your insight. We just uploaded v1.0.3, which should fix the issue you are running into on BIG-IP v12.0. Let us know if you have any additional trouble or questions.
- pkwilly_224337
I am trying to use this iapp with version 12.0 and get error (01020036:3: The requested customization_group (/Common/SWG_DCAgent.app/SWG_DCAgent_apm_HTTP_401_response) was not found) When trying to create the application.
