C# Making Async Calls using the iControlAssembly
Problem this snippet solves:
This C# example application shows three different ways to make iControl calls Asynchronously using the An iControlAssembly library. Each way serves a slightly different purpose depending on the needs of the application.
Code :
using System; using System.Collections.Generic; using System.Text; using iControl; using System.Diagnostics; using System.Threading; namespace iControlAssemblyAsyncExample { class AsyncExample { private static Thread mainThread; static void Main(string[] args) { Stopwatch sw = null; Interfaces m_Interfaces = null; IAsyncResult ar = null; string[] poolList = null; //////////////////////////////////////////////////////////////////////////////// // Synchronously connect to the BigIP Appliance Console.WriteLine("Establishing connection to Appliance."); sw = Stopwatch.StartNew(); m_Interfaces = new Interfaces("hostname", "username", "password"); Console.WriteLine("Connection completed in {0} ms\n", sw.ElapsedMilliseconds); //////////////////////////////////////////////////////////////////////////////// // Synchronously Retrieve the Pool List Console.WriteLine("Beginning syncronous Pool list retrieval."); sw = Stopwatch.StartNew(); poolList = m_Interfaces.LocalLBPool.get_list(); Console.WriteLine("Syncronous retrieval completed in {0} ms\n", sw.ElapsedMilliseconds); //////////////////////////////////////////////////////////////////////////////// // Asynchronously retrieve the Pool List, do something and then wait // for the Async call to complete. Console.WriteLine("Beginning async retrieval with wait."); sw = Stopwatch.StartNew(); ar = m_Interfaces.LocalLBPool.Beginget_list(null, null); // Do some work, which may or may not take longer than // the Async call to execute. Console.WriteLine("Done some work after {0} ms. Now waiting.",sw.ElapsedMilliseconds); ar.AsyncWaitHandle.WaitOne(); // Wait indefinitely for the Async Call to complete ar.AsyncWaitHandle.Close(); poolList = m_Interfaces.LocalLBPool.Endget_list(ar); Console.WriteLine("Asyncronous retrieval completed in {0} ms\n", sw.ElapsedMilliseconds); //////////////////////////////////////////////////////////////////////////////// // Asynchronously Retrieve the Pool List while doing something indefinitely. Console.Write("Beginning inline async retrieval"); sw = Stopwatch.StartNew(); ar = m_Interfaces.LocalLBPool.Beginget_list(null, null); while (ar.IsCompleted == false) { Console.Write("."); // Continually to something until the Async Thread.Sleep(15); // call has completed. } poolList = m_Interfaces.LocalLBPool.Endget_list(ar); Console.WriteLine("\nAsyncronous retrieval completed in {0} ms\n", sw.ElapsedMilliseconds); //////////////////////////////////////////////////////////////////////////////// // Asynchronously Retrieve the Pool List with a Callback AsyncCallback myCallBackRoutine = new AsyncCallback(MyAsyncCallback); mainThread = Thread.CurrentThread; Console.WriteLine("Beginning Callback Async retrieval"); sw = Stopwatch.StartNew(); ar = m_Interfaces.LocalLBPool.Beginget_list(myCallBackRoutine, m_Interfaces); try { while (true) { Console.Write("."); // Do something useful while we Thread.Sleep(15); // wait for the Callback to complete. } } catch (ThreadInterruptedException) { Console.WriteLine("\nAsyncronous Callback retrieval completed in {0} ms\n", sw.ElapsedMilliseconds); } Console.WriteLine("Press ANY key to exit."); Console.ReadKey(); } private static void MyAsyncCallback(IAsyncResult ar) { Interfaces m_Interfaces = (Interfaces)ar.AsyncState; string[] poolList = m_Interfaces.LocalLBPool.Endget_list(ar); int c = 0; while (c < 7) { Console.Write("X"); // Do something useful while the main Thread.Sleep(15); // thread is doing what it needs to c++; } mainThread.Interrupt(); } } }
Published Mar 07, 2015
