T0nyP
Jan 04, 2024Cirrus
Solved
Recommended Persistence for F5 working as ISP-LB ( ISP Load Balancing )
Just want to ask based on your implementation experience what is recommended persistence for ISP Load Balancing? ( Source IP Persistence or Destination IP Persistence )
Thanks.
i cant find related f5 kb on that.
however, ideal ISP load balancing should persist source&&destination ip address.
hash persistence allows to create such persistence object.
if persisting on source ip address only, access from 1 client will only uses 1 isp.
