cgwin12's avatar
cgwin12
Apr 25, 2024
Need help on i-rule to specific uri path
Hello All,
I'm working on an i-rule that I need to do the following; given a set of specific source ip addresses, only allow access to specific uris of /ws/rest/external*.
I set the specific source addresses in a data group, referencing the data group. When I apply this i-rule to the virtual server, on testing I get an Insecure HTTPS message. I am on version 15.8.1.2. We plan to upgrade to most stable release on 16 soon.
Any suggestions on what I can do with the i-rule posted below? Thanks in advance.
when CLIENT_ACCEPTED {
  if { [class match [IP::client_addr] equals Boomi_external] } {
     pool esd-bmapi-dc1-as01-f5.lanl.gov_8077_pool
if ![HTTP::has_responded] {
if { ([HTTP::host] equals "apigway-d.lanl.gov" or [HTTP::host] equals "apigway-d.lanl.gov") } {
    if { [HTTP::uri] starts_with "/ws/rest/external*    " || [HTTP::uri] starts_with "/ws/rest/external*" } {
    else { reject }
    return
  • Try below
    	    switch -glob [string tolower [HTTP::uri]] {
    	        "/ws/rest/external*" {
                 reject
    	        } default {
                drop
  • The insecure HTTPS message is very unlikely to have been caused by your iRule - most likely it is because the server IP/name you are going to in order to reach the Virtual Server does not match the CN in the SSL certificate returned by the pool member.
    Regarding the iRule; I strongly suggest using [HTTP::uri -normalized] to ensure that your iRule cannot be bypassed by encoding slashes or other bypasses (e.g. //, //./, %2F etc) (everyone should be doing this, really!). Other than that, Sanjay's rule above should be more efficient.
