- JmtaylorModerator
Prakin Hello I found this article that may provide you with the information you requested.
Determining the maximum allowed throughput rate on the BIG-IP VE system (f5.com)
- PrakinCirrus
Thanks, how about for the hardware platform?
Hi Prakin,
You can try using tmsh to view throughput statistics
Impact of procedure: Performing the following procedure should not have a negative impact on your system.
Log in to tmsh by entering the following command:
tmshTo view the current total throughput represented in bits and packets, enter the following command:
show sys performance throughput
You can add the historical option to also view 3 hour, 24 hour, 7 day, and 30 day historical increments by entering the following command:
show sys performance throughput historical
To view the current total TMM throughput statistics represented in bits and packets, enter the following command:
show sys performance throughput detail
show sys performance throughput detail historical
Displays detailed throughput performance information in gigabits per second.
show throughput gig detail
HTH
- PrakinCirrus
Thanks for the detailed info, i am also looking for the maximum throughput supported by the hardware platform by design.
- JmtaylorModerator
I looked up some of the it depends on what model and what setup you have. Did you have any in mind ?
- PrakinCirrus
actually i am looking for diff models that we have like 12800, i4800, 15800. is there anyway can we fetch the info from the CLI for the maximum throughput.
No there is no "limitation" by design. Its limited by the interfaces and hardware caps. Look up datasheet of your model.
i-models are old! r-models are new!
